Are 4150 main bodies all the same?
Subscribe
Feb 3, 2018 | 05:33 PM
Im working with an 80537 750 cfm DP Holley, its a marine carb. The probnlem i am having is the port for the acclerator jets is craked so I cannot bolt the jet housing down on the primaries. Im looking at replacing the main body but Holley show that there is something different about the marine carb that makes it more...mariney I guess....other that the zink coating that is worn off this one. Can I get something like a Proform main body and use my metering block, throttle body, float bowls ect. on off the 80537?
Reply 0
Feb 13, 2018 | 05:56 PM
Re: Are 4150 main bodies all the same?
All will bolt on,u r looking on the butterflies for 172 diameter they use the same ones for 700 750 for sure maybe 800 i think 850 r bigger but not pos just match the number on the bottom it will work
Reply 0
Subscribe
