383 Stroker & AFR L98 Heads - Lancaster CA 93535
Car: 1991 Chevy Mixed Camaro
Axle/Gears: I think 2.77
For Sale is a pair of AFR 195 aluminum Heads.
There in excellent condition basically brand new, ready to be bolted on.
Fits any small block Chevy V8
66cc Combustion Chamber, 2.02 / 1.60 Valves
Intake Flows 210cc, They fit Any Small Block Chevy V8.
They have been professionally ported and Polished, come with upgraded
LS style Bee-hive springs and Titanium locks & Retainers.
AFR push rod guides, comp Cam Roller rockers, ARP Head Studs included
<a href="http://losangeles.craigslist.org/lac/pts/5779317449.html">CL AD</a>
385 Stroker Small Block Chevy
11:3 Compression Ratio with 66cc Chamber
EVERYTHING was Bought Brand New.
350 block - 1 Piece rear main
Bored .040 Over
Decked .017
Brass Freeze Plugs
Fully balanced
Forged Scat 3.75 Balanced Crankshaft
ARP main studs
H-Beam Forged 5.7 Rods with ARP rod bolts
Clevite 77 Main and Rod Bearings
Probe Forged Floating Flat Top Pistons -4cc
Hastings Performance Moly Piston Rings
Melling High Volume Oil Pump
Moroso Big mouth oil pump pick up
Moroso Steel Oil pump shaft
Moroso Rear main oil deflector
Solid High Performance Harmonic Balancer
Under-Drive Pulley
<a href="http://losangeles.craigslist.org/ant/pts/5780885924.html">CL AD</a>
661 874 2434 willing to meet half from Lancaster
Bored .040 Over
Decked .017
Brass Freeze Plugs
Fully balanced
ARP main studs
Under-Drive Pulley
Car: 1987 Camaro
Engine: 383
Axle/Gears: Working on that
Re: 383 Stroker & AFR L98 Heads - Lancaster CA 93535
Interested in the heads if they are still for sale. Shipped to 82801
Kblakney
Sep 21, 2016 10:03 AM
CustomTPI
Sep 11, 2016 02:10 AM
