Stewart aluminum stage 2 pump users
Does the Stewart stage 2 Aluminum pump have the internal bypass port on the passenger side. (The third hole). My block is a World Motown 2 sbc that isn't drilled for the bypass port. I couldn't find any online pictures of the mount side of the pump. Thanks for your time.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Stewart aluminum stage 2 pump users
I'll check mine when i get home. I got two, one reverse rotation for L98 serp systems and one regular that i used on my dart block sbc. I think i still have them both
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
These are pics from my 91 305 with the Stage 2 Stewart aluminum pump EMP-23123. Hope this helps.
If your block lacks the extra little port, drill & tap the WP for a ¼" pipe plug. Or, drill it to some common size such as ½" dia and use a welch plug.
Michael Canfora
Sep 19, 2016 04:55 PM
1BADZ28SD
Sep 12, 2016 12:57 PM
aaron7
Sep 6, 2016 11:31 AM
m300slr
Sep 2, 2016 08:04 PM
