CarburetorsCarb discussion and questions. Upgrading your Third Gen's carburetor, swapping TBI to carburetor, or TPI to carburetor? Need LG4 or H.O. info? Post it here.
Hello All,
I've got an 82 Camaro with a 305 and Quadrajet that I believe to be original. Electric choke. The pull off has a line going from it to the base of the carb, as shown in the picture. There's a tee where it goes into the carb and right now there's nothing attached to that tee. I assume it needs to be hooked up to vacuum in order for the pull off to work. Does anyone know where I should be running a vacuum line to? Thanks
The carb is the vacuum source. The vacuum line to the air cleaner hooks to the other side of the T. If you aren't using the stock air cleaner, cap the T.
I see you still have the original "coaxial" style CTS connector. That thing is DEATH. You should get rid of it. Replace with the newer version (from 30 yrs ago or less) with the 2 pins. They can come with the new pigtail when you buy them at the parts store. Physically open the box and inspect to verify that the pigtail is in the box.
Found the line on the air cleaner and it's now at home on that vacuum port on the carb, so all is good. Choke pulloff seems to be working good. Thanks for the advice on the CTS connector. I'll put that on the long list of things to do.
