Choke vacuum line
Old Jan 16, 2002 | 08:50 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
Choke vacuum line
I'm connecting the vacuum lines for my carb swap, and the only line I have left is the one for the electric choke. Can I tee it into an existing line or does it have to have its own port? Here's how I ran the lines:
power brakes---PCV port on carb
PCV valve---vacuum port on intake manifold
vac. advance---vac. advance port on carb
Where should I run this line? Thanks.
Old Jan 17, 2002 | 05:58 AM
gmanuel's Avatar
Re: Choke vacuum line
I think that you have a couple of lines reversed. The power brakes should be connected to the intake manifold so that there is a good source of vacum all the time. The pcv should be connected to the carb. As for the choke there should be vacuum port quite close to where it mounts on the carb and the line is S shaped. It is the choke pull off. I am assuming that you have a qjet carb.
Old Jan 17, 2002 | 03:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I agree with the comments about the lines you've connected.
I assumed you were talking about the Holley in your sig. If so, there is no such thing as a choke pull-off vacuum line.
Old Jan 18, 2002 | 01:30 AM
Fbird88's Avatar
Car: 1988 Firebird
Axle/Gears: :(
Hmm, I guess I got the vacuum lines mixed up. Thanks, gmanuel, for pointing that out. I read in the TBI-->Carb tech article that the guy used the PCV port on his carb for his power brakes, so I ran the lines that way. After reading it a little more carefully, I can see he did that because he put a breather in place of the PCV valve. I'll route them the way you suggested.
This is for the Holley DP in my sig. I converted it to electric choke. That's why it now has the vacuum line. In the instructions that came with the choke, it says to tee it into any full manifold vacuum line. What would be an example of a full manufold vacuum line? Five7, thanks for your help with this and the spacer problem.
Old Jan 18, 2002 | 07:55 AM
gmanuel's Avatar
Full manifold vacuum can be tapped into the vacuum line for the power brakes
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
