Intake for zz4
Old Jan 16, 2002 | 07:16 PM
zz28's Avatar
Intake for zz4
I have a 92z with a zz4 that i bracket race and drive. Will a Perfomer RPM help? Somebody said if you cut a 1/2'' out of the plenum it helps? I run a 650dp w/1'' spacer and a BTE powerglide,
Old Jan 29, 2002 | 01:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, nobody else took a shot at this.
I'd think the RPM would be fine the way it is. A slightly bigger carb (or a Demon) might help as well.
On that track, that is. I assume you currently have the ZZ4 intake on there. On the street, it's probably a little better until you're getting the R's up, where the RPM would take over.
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
Magman
Sep 13, 2015 12:14 AM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
