Afpr Vacuum Compensation
Old Jan 16, 2002 | 09:17 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Does any of you use this port on the AFPR? A hose goes from the AFPR port to the carb or manifold vacuum source and is supposed to lower fuel pressure at idle and part throttle.
Is this worth doing?
Old Jan 17, 2002 | 07:24 AM
82camaro's Avatar
Car: 82 camaro SC
I can't see the why you would need that with a carb. A carb is meant to have a constant pressure at all times.
Old Jan 17, 2002 | 10:01 AM
Jester's Avatar
Definatly not. Thats mostly just for boosted applications that might need higher pressure under boost.
Pac J
May 17, 2020 10:44 AM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
