Holley Fuel Inlet Fitting
Old Apr 2, 2022 | 09:33 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
What is everyone using for the fuel inlet fitting on Holley single- feed carbs under a drop base air cleaner?
I have a basic 350 in my 92 with a stock Qjet intake manifold, Holley 4160 single inlet with vac secondary, and a 1 3-4" drop base air cleaner. I can't get the hose to bend enough to fit a straight hose barb fitting under the air cleaner base and haven't been able to find a compatible swivel fitting with a 3/8" hose barb on it.
Previously, I had mocked something up using some brass plumbing fittings and it worked, but it's ugly and occasionally seeps fuel. I also had to wrap all of it heat reflective tape to keep the fuel cool enough to avoid problems.
Any and all suggestions are welcome.
caddyescalade
Carburetors
Aug 26, 2020 10:41 AM
Cameron Abeel
Carburetors
Oct 18, 2017 02:32 PM
DerrenZ
Jun 23, 2011 11:01 PM
TPI-Formula350-
Jul 8, 2009 07:49 PM
Manic Z
Carburetors
Jun 28, 2003 09:14 AM
