Just to be sure. 700R4 TV cable brackets
Have to swap carbs on my '86 as the carb that was on the car had a broken baseplate.
So I am having to put my other 650 DP on.
For the TV cable I just want to make sure that the below brackets are the correct ones I need as the other carb had something on it but I dont like the Throttle bracket the way it mounts so I want to order something else.
This is the cam
https://www.summitracing.com/parts/hly-20-121
This is the cable bracket
https://www.summitracing.com/parts/qft-49-95qft
Then its just adjusting the TV cable.
Is that all I need?
This is the cam
Is that all I need?
