What is this located slightly behind alternator? Leaking gas.
Old Dec 31, 2024 | 09:44 PM
Phantomwydd's Avatar
1985 v8 5.0 trans am 305 carb
Old Dec 31, 2024 | 11:22 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: What is this located slightly behind alternator? Leaking gas.
That's your fuel pump. Probably get it sorted out before you drive it any more. Could be the pump or one of the rubber lines attached.
Old Jan 6, 2025 | 03:57 PM
LunarEclipse's Avatar
Car: 1983 Trans Am
Fuel pump. Mine was leaking out the side of the housing through the weep holes and replaced it.
Old Jan 7, 2025 | 10:26 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Definitely agree, fuel pump. Don't drive it until you fix it. Any old pump will do for most engines, the Carter ones are pretty reliable.
72buickgs
Sep 5, 2024 11:21 AM
Freebird1985
Nov 11, 2022 10:02 AM
ktthecarguy
Jan 16, 2022 10:57 AM
86WS6
Jul 9, 2019 04:34 AM
