Vacuum hose on choke? not talking about choke pull-off
Old Feb 6, 2002 | 07:01 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
Hello I have a 78 q-jet .....now i dont know if this tube coming off of the choke housing is some sort of heat collector or some kind of vacuum hose connection. I'm not talking about the choke pull-off that connects to the top portion of the carb on the left hand side. MY question is what do i connect this too??? thanx
Rob
Old Feb 6, 2002 | 10:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You have the famous "hot air" choke.
A tube is run via a plate bolted to a boss on the intake manifold into the exhaust cross-over passage of the manifold (the April 2002 CHP magazine that arrived in the mail today has a picture of a manifold with that boss on page 56 - the boss in front of the EGR boss). A small amount of air is allowed to flow through that tube via a small vacuum passage in the choke thermostat housing to manifold vacuum, which is warmed by the exhaust gases as it goes through the tube. The warm air then warms the choke thermostat, causing it to open the choke butterfly as the engine warms up.
If you don't have a manifold with that hot air boss, and don't have the tubes required to make it work, you can convert it to electric very easily. The thermostats are the same size, and just put a cap on the hose nipple on the housing.
Old Feb 7, 2002 | 11:47 AM
Car: 1983 Z28 Clone
Transmission: TH350
thanx...sounds like a project for today........
Rob.....
sailtexas186548
Feb 17, 2017 03:07 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
