Non-Third Gen but...
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I just bought a beater. Tired of driving my 1972 around in winter. Anyways. The only problem mechanically is that the car will die at the stoplight unless you have your foot on the gas and also die when given too much gas. Is this just carburator tuning? i was thinking idle speed maybe. BTW its a 86 carbed 305. Thanks
Transmission: 4L80E/4L80E
I doubt it's just the carb.
Check all your tune-up items: plugs, cap, rotor, wires, timing. Then, do the carb stuff - idle speed, choke adjustment and pull-off, secondary opening (& rods/hanger if necessary).
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
