750cfm too big?
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
750cfm too big?
If Holley recommends 650cfm for a 383, what actual impairment to performance can there be if you have a 750cfm? If your exhaust flows enough to match your carb, it doesn't seem like it would matter.
:hail: IROC-Z
:hail: IROC-Z
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
A 750 cfm rated carb is rated at a pressure drop of
1.5 "hg. A 383 at wide open throttle will only pull a vacuum
guage reading (pressuredrop) of about .5" hg. A 750 cfm carb, when flowed at a pressure drop of .5" hg will flow a lot less than 750 cfm,
around 550@.5" hg. A 750 cfm carb is not too big for a 383.
I currently have an Edelbrock Performer 750 carb on a 355 with a Weiand Stealth intake, double hump heads, short tube headers and a Comp cams 244/244 duration .501/.501 lift cam and it runs excellent with this carburetor. However I would reccomend getting a slightly smaller set of jets put in it than what came from Edelbrock.
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
