fuel cooler/coolcan
Old Feb 17, 2002 | 03:59 PM
jamesbern's Avatar
fuel cooler/coolcan
I was wandering about the use of a fuel cooler or a cool can. Has anyone tried one and was it worth the time/money? I figured it would be quite easy to rig one up with some metal line and a coffee can, but I don't want to waste my time if it doesn't provide a significant gain. The track is finally open and it is time to pull out some quick last minute goodies. Thanks!
Old Feb 18, 2002 | 08:48 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
I Experimented with this type of thing awhile back.Instead of a cooler can ,i used armorflex wrapped around the fuel line from the pump to the carb to protect it from the heat.I found that keeping the fuel cool didn't seem to do much for power,and it had a negative effect on my gas mileage.Keep in mind that i was only using my butt-dyno and had no track time to back this up.Different combinations may get a different result also.I think you'd be better off trying to cool the air intake charge.
Old Feb 18, 2002 | 10:08 AM
Jester's Avatar
I've heard of it being worth like a tenth...maybe..if you fill up the can with ice water. Never tried it myself.
Old Feb 18, 2002 | 07:17 PM
jamesbern's Avatar
Thats what I mean, if you add ice before a race will I gain a tenth or so. It would only be about an hour or two of work and about $10 worth of parts to build one. If I don't hear from someone who has tried it then I will post results. Thanks!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
