Uneven Burn after Carb swap.
Old Feb 18, 2002 | 12:56 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I have just completed my TBI to carb swap and have been working out the details. I have found that I am having an uneven burn problem with the plugs. #1..2..6 are BLACK 3..4..7.. are a little used 5..8...are almost clean as new.
Any ideas where to go with this.......There is no knock and it runs pretty well.
Brian
Old Feb 18, 2002 | 02:15 PM
Jester's Avatar
Sounds more like an ignition related problem than the carb. Check out the plugs, wires, cap, rotor, pickup coil, etc.
Old Feb 18, 2002 | 05:08 PM
Well they are all new. I have the proform HEI from Jegs and the wires are not new however they have al little over 2000 miles on them. If you are thinking ignition what plugs would you think are running correctly..........Very white? The plugs are new.........less than 40 miles on them
Thanks for the help
Brian
Old Feb 18, 2002 | 07:55 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
I had to set my timing up quite a bit after my swap from 6* to 12 - 14* advanced. May try that. If it doesnt help, maybe there is some cross fire happening or a vacuum leak.
:hail: IROC-Z
Old Feb 18, 2002 | 07:57 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
I had to set my timing up quite a bit after my swap from 6* to 12 - 14* advanced because of the same thing. May try that. If it doesnt help, maybe there is some cross fire happening or a vacuum leak.
:hail: IROC-Z
Old Feb 19, 2002 | 09:17 AM
Stroked-Z's Avatar
What type of intake did you bolt on???
And what is your plug gaps set to?
You should go over your ignition system & check it out.
Old Feb 19, 2002 | 11:25 AM
Intake was Perf RPM.........plug gap was 40 however I widened it to 60 last night. The bast time is set at 12*
brian
Old Feb 19, 2002 | 02:51 PM
Stroked-Z's Avatar
Your supposed to get a better burn by widening the gap...BUT
You dont have any sort of hi-po ignition ect....or wires....
So i would be gapping at .032"
60 is too wide. Although those old 301 Pontiacs did use a 60 gap from the factory, i dont understand why.
I am willing to bet that too wide of a gap is the problem though.
Old Feb 19, 2002 | 03:00 PM
Well I have the Proform HEI coil and module with the MSD 6al. I Had it at 40 and now that I moved it to 60 it did help......there is no misfire.
Brian
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
db057
Apr 28, 2019 07:45 AM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
