I've been doing a lot of searching on the board and am trying to find the correct parts and part #'s for running the stock fuel lines from the driver side frame to a Mallory 3 port fuel pressure reg. to a carb, I've been having a H**L of a time trying to find the correct adapters/connectors. If anybody can help me out on this one it would greatly be appreciated. I know some people have used swivel fittings in their setup, but I was looking to try and keep the price down with just straight fittings.
Thanks,
Scott
Thanks,
Scott
well I did the same thing.......I just cut the ends off the stock lines then ran the rubber lines up to the regulator and used spider clamps to hold them on to the inlet fittings.
Brian
Brian
