q jet not responding...to mixture settings
Old Mar 8, 2002 | 02:22 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
hey guys... i can turn my idle mixtures on my 78 q jet.....with no response....the car runs like its got a HUGE cam in it....rough idle.......i can tighten the screws closed... AND THE CAR STILL RUNS with no response....i've just rebuilt the carb...it was doing that before.........i look down the front bore and i can see gas spraying inside of the little venturi?? the little tubes sticking up.......if i look at the fuel vent.. i can see gas really up high.....it just started again............................... problebly fooding ...I JUST REBUILT THE THING.. it was fine.. and now its acting up again with the same problem..
thanx
rob
Old Mar 20, 2002 | 04:42 PM
Teddy Z's Avatar
Sounds like your float level is too high.
Old Mar 20, 2002 | 09:40 PM
Car: 1983 Z28 Clone
Transmission: TH350
well....your partially right.....after i did the rebuild i hooked up the fuel line... duh..............but...i'm not running a filter in the carb..just an inline.. soo... when i pushed the rubber hose onto the jagged pipe that goes into the carb...a piece of rubber came off ..and loged between the seet and needle...
theshackle
Sep 17, 2020 08:26 AM
colton_carlson
Mar 8, 2019 12:21 PM
fasteddi
Sep 2, 2015 10:29 AM
hydrolic144
Aug 29, 2015 04:14 PM
mustangdmurder
Aug 21, 2015 07:17 PM
