Help! striped threds on holley fuel bowl
Old Oct 6, 2000 | 09:20 PM
GOLD85's Avatar
i have a holley 650 double pumper and noticed that the secondary fuel inlet was leaking a bit. i atempted to tighten the fuel fiting, but insted striped the threads. i dont feel like spending $70 on a new bowl, so i would like to fix the threads, any sugjetions on how, keep in mind i'm prety much broke
when the green flag drops the bull$hit stops
350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Old Oct 6, 2000 | 09:26 PM
Jester's Avatar
Well..the fuel inlet is a 2 piece thing.There is an adapter piece that screws into the bowl, and the fuel fitting screws into that. Are the threads in the bowl actually stripped or the threads in the adapter? If it's just the threads in the adapter thats easy...you can get a new one for a couple bux. if it's the threads in the bowl you can try JB Welding it. So long as you don't move it arond too much it should hold.
Old Oct 6, 2000 | 09:52 PM
GOLD85's Avatar
its the fittings in the fuel bowl the adapter goes into. i think this is a pretty dumb system. should i just put some JB weld in the bowl and put the fitting in. could you pleas help.
Old Oct 6, 2000 | 10:19 PM
Jester's Avatar
coat the threads in JB Weld, and screw it in as tight as ya can. let it dry and call it good.
Old Oct 7, 2000 | 12:15 AM
EvilCartman's Avatar
Car: '82 Z28
Would it be possible to install a helicoil? Local machine shop might be able to do it.
Old Oct 7, 2000 | 05:06 PM
GOLD85's Avatar
unforntatley stupied has ther own therd pitch, un less holley has a heli coil i can not use a heli coil, thanks for the sugestion though, i think i will try the JB weld
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
