Crazy idle problems!!!!!! WTF???
Old Oct 29, 2000 | 08:56 PM
spitfire350's Avatar
Ok first of all my problems started when my choke heater relay burned up. To tell you the truth i have no idea how long it was broken. But i recently replaced it. So after i replaced it just to be safe i disconected the negative battery terminal for about 30 min. and then drove the car around like i normally would to reset the ecm. but while i was driving around i noticed that the choke light was constantly on. And the idle was wierd. As for the idle, when I am in 4 th gear and i clutch to slow to a stop the idle slows to 1300 RPM and then, right before i stop it slows more to 800 RPM, where it has always idled. And also when the car is warm the choke light is still on. If any one knows whats wrong with it please let me know.
thanx
keep the stang's far behind u and the cops even farther
Old Oct 30, 2000 | 12:47 AM
Ratnose86SC's Avatar
check yo fuses
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
