What is the best carb for a 250hp 350ci? ..best performing? ..best price?
Old Nov 5, 2000 | 10:14 AM
chris83z28's Avatar
It looks as though I am going to have to buy a new carb. I have had Edelbrock carbs in the past and was not happy with the dependability. Should I just trade in my only computer controlled quadrajet in for a newly rebuilt mechanical one? (I have a vacuum advance dist.) The comp. controlled one on there now isn't doing so well because of the dist. I don't want to put in a 18 year old dist from the 305 in the new motor. What about the street demon or speed demon?
Old Nov 7, 2000 | 09:16 AM
Damon's Avatar
Either one of those will work great. I can't really say which one is "best" since I just look at a carb as a fuel mixing device and ANY carb will work great if properly tuned thoughout the entire RPM/load range. But out of the box the carbs you mentioned are probably closer to optimum than any stock Holley or QJet.
94 Firebird Formula M6- No options but Z rated tires. No mods over $10. 13.5@105.
79 Malibu "beater" w/junkyard 400 SBC, tweaked QJet 4bbl, finally a decent set of heads, a few other tricks. A maddening 13.000001 @ 108 on the motor with little traction. No nitrous runs with the new heads yet.
Grandma's old 78 Malibu (33K miles!) soon to have the powertrain from the 79 put in it.
"One of the last remaining QJet tuners on Planet Earth!"
Infested
May 22, 2018 11:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
