where to start (gauge ???)
Old Oct 29, 2000 | 07:54 PM
JJ's Avatar
JJ
I finally got my car started and running - new everything (gmpp 350, holley 650 dp, ect.) I don't know a lot about carbs so I set the idle and timing and went to Barnes and Noble and bought a book about holley carbs. Car runs "ok", but may have a miss, can't quite tell with the cam. I guess to my point, is there some kind of gauge that tells air/fuel mixture ? I thought there was and that would make it a lot easier for me.
How would a car idle with a 110LS cam, it is hard to tell what is going on when everything is coming through one intermediate pipe. I got the lope, but it seems as if there is a slight "pop,pop" mixed in there. Oh well, I have all winter.
Thanks guys
Old Oct 29, 2000 | 11:31 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Thirdgen.org's O2 Sensor Tech Article.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Oct 29, 2000 | 11:40 PM
JJ's Avatar
JJ
oops, no computer either . . .
Old Oct 30, 2000 | 10:22 AM
MRZ28HO's Avatar
Engine: was: L69
You don't need a computer, only an O2 sensor and multimeter.
Old Oct 30, 2000 | 03:28 PM
JJ's Avatar
JJ
ahh, it is becoming clearer . . .
Old Nov 9, 2000 | 10:55 PM
82z's Avatar
82z
I like my intellitronix a/f ratio gauge. It looks sharp and it works. Remember that o2 sensors are only accurate around 14.7. To track mixtures much richer or leaner you need some serious hardware like an ngk 5 wire sensor and it's hardware or an etas a/f ratio meter.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
