I don't think my choke is working.
Old Nov 8, 2000 | 11:40 PM
matthew's Avatar
I have the stock LG4 carb. When I get in it first thing in the moring, I always push the accelerator all the was down and then start it. this used to work perfect, the car would start right away and rev up to like 1500 rpms. Now I do the same thing, but it doesn't rev up like its supposed to. it just sits there at 500 rpms and shakes the whole car. I have to step on it to bring the idle up a little bit. this is getting really annoying. Any help would be appreciated.
yellow 86 Camaro LG4
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Old Nov 9, 2000 | 09:05 AM
Damon's Avatar
Probably something's getting sticky/dirty in the linkage. When the engine is overnight-cold go out and take the air cleaner off. Open the throttle manually by hand and watch the choke. It should SNAP closed. If it doesn't the linkage is probably sticky/dirty or the choke element on the pass. side has broken internally. THe first one is usually an easy fix with some carb cleaner and working the linkage. The latter requires drilling out the rivets that hold the choke element in place and replacing the element with a new on ($40 from an auto parts store).
94 Firebird Formula M6- No options but Z rated tires. No mods over $10. 13.5@105.
79 Malibu "beater" w/junkyard 400 SBC, tweaked QJet 4bbl, finally a decent set of heads, a few other tricks. A maddening 13.000001 @ 108 on the motor with little traction. No nitrous runs with the new heads yet.
Grandma's old 78 Malibu (33K miles!) soon to have the powertrain from the 79 put in it.
"One of the last remaining QJet tuners on Planet Earth!"
Old Nov 10, 2000 | 10:57 PM
matthew's Avatar
any other opinions?
Old Nov 13, 2000 | 07:35 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
No, he covered everything that could possibly be wrong...
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Jote4805
Aug 25, 2015 06:11 PM
justin57
Aug 20, 2015 07:05 PM
1985chevydude
Aug 20, 2015 12:29 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
