fuel filter
fuel filter
okay, this is a lame question, But on the rochester Built in fuel filter, wich way does it go ? I replaced mine and wasnt paying attention When I pulled the old one out, Now the car is starting to Sputter so Im pretty Sure its in backasswards, but its really Cold outside and I dont want to Go work up to my elbows in freezing gasoline atm.
Does the hole in the filter face the carb, or the Supply Line ? I think I put the hole towards the carb, But Not sure
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
Transmission: 4L80E/4L80E
The hole in the filter faces the supply line. The spring goes into the carb first, then filter.
The idea is that the stuff that is filtered out will stay in the filter when you replace it.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
1992 Trans Am
May 10, 2023 07:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
