Hooking up Mallory regulator
Old Dec 3, 2000 | 08:25 PM
railroadrad's Avatar
I did a carb. swap from tpi. It is on an 85TA. I got a Mallory 3 port fuel regulator. How do you hook it up. What kind of fitting do I need. What about the pump relay. I have a 350, Qjet, factory fuel pump and lines.
Old Dec 4, 2000 | 10:16 AM
SeanSullivan's Avatar
I put a mallory on my tbi to carb conversion, the bottom port is the return to the tank, the other one can be used for supply in, another for supply to the carb. I set my psi to 5lbs. DO NOT use teflon tape for thread sealant, use a paste you can get at ace hardwar specifically for fuel and oil.
gixxer92
May 18, 2017 11:20 AM
2012sergen11
Oct 13, 2015 07:38 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
dusterbd
Sep 29, 2015 08:40 AM
