Best Hangers and Rods for Q-jet
Old Mar 27, 2002 | 03:10 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
What primary and secondary rods should I use and hanger? What is the best?
Old Mar 29, 2002 | 08:54 PM
jrr's Avatar
jrr
Scroungin' for Q-Jets is getting really tough but here goes.
I'd use a Q-Jet that has a model number like 702xxxx to 704xxxx.
Those are carbs from late 60's to 1975. After that, the carb were numbered as 1705xxxx. The 1705xxxx models are pure smoggers and good primary rods (narrow taper) are hard to find but I thing Edelbrock may have something to offer. If you get one of the good older pre-1976 carbs, I'd start with # 69 jets and #38 - 40 primary metering rods. Those are single taper rods BTW. The double taper rods can go a tad leaner, up to 41b - 42b for fuel economy and still be rich when you floor it. A good rule of thumb for primary rods is for the jet number to be roughly 30 more than the metering rod number.
The seconday rods won't matter as much because those LG4 heads just don't breathe. I've used CC,CV, DD (super lean!), DL, and some really rich rod that made more smoke than power (can't find the dumb things!). The garden variety I, J, and K hangers seem to do O.K. I went back to the lean CV to keep the smoke to a minimum. The DL was a good rod too.
Old Mar 30, 2002 | 07:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've used AH secondary metering rods with a G hanger and currently DR rods with a B hanger. Both improvements, in my opinion, over stock.
JamesC
Old Mar 30, 2002 | 11:05 PM
johnyIROC's Avatar
You can't go by the SOTP (seat of the pants) dyno. It may sound meaner when you are running super rich... but it's not necessarily performing better.
If anyone knows good rod/jet/hanger combos for mild 350's let me know.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
