would i be able to hear a vacuum leak inside my car?
Old Mar 22, 2002 | 11:57 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
lately my car has really been runing rough.......my secondaries wont really open only like a 1/8th of an inch.....the car is hard to start.....and i hear a rushing air noise with every crank of the motor.........any ideas?
Old Mar 23, 2002 | 03:04 AM
Stroked-Z's Avatar
Vacuum leaks sound like whistling. If that's what you hear, that's what you got!
Old Mar 23, 2002 | 10:46 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
That is odd... normally you can't hear a vacuum leak... Which may mean it's a really big one in your case... I don't know about your problem, but a vacuum leak usually produces an inconsistent idle (rising and falling) and dieseling (engine runs a few seconds at very low RPM after shutting the car off).
You should start by eliminating the possiblity of a vacuum leak... but I wouldn't be surprised if it was a simpler problem.
Old Mar 23, 2002 | 10:54 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
my bro thinks there is something cloggin the secondaries or something
im prolly just gonna have it rebuilt
Old Mar 24, 2002 | 11:58 PM
Stroked-Z's Avatar
All the vacuum leaks i have found by listening
Old Mar 29, 2002 | 07:32 PM
Camaro Cra-Z's Avatar
have u checked the vacuum lines going to your heater control
Old Mar 29, 2002 | 09:45 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
forget about it
yah my heater hoses are messed up too but i know what that sounds like....and im positive its just the primaries trying to suck in a whole bunch of air since my secondaries arent opening...
Old Mar 30, 2002 | 11:17 PM
johnyIROC's Avatar
If it's leaking from the heater controls, you would definitely hear it inside. Mine was leaking after I installed a CD player, and it was noticable to say the least.
specialized
Jun 18, 2022 09:26 AM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Kaweh
Aug 9, 2015 02:54 PM
