Effects of Spacers on preformance?
Old Jan 14, 2001 | 07:44 PM
ede's Avatar
ede
what does a spacer change? what changes as height increases? looking in jegs i can buy from 1/2" to 2" spacers or heat shields. would a spacer increase HP or torque.
ICON Motorsports
1st & 3rd
Old Jan 14, 2001 | 11:24 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
A spacer is a great tunning device that can fine tune a carb. Adding a taller spacer will lean the fuel mixture out without rejetting. The design of the spacer has more to do with HP and torque than the height.Adding a spacer with a four hole design will add torque to your engine while a open design spacer will add HP because you increase the plentum volume of the intake. Don't waste your money on a aluminum spacer,they transfer heat to the base of the carb and heat the fuel mixture as it is swept down into the intake.Spend a little extra and get the phenolic spacer.Unlike the aluminum, it does not transfer heat and creates a denser fuel charge.
Old Jan 15, 2001 | 01:48 AM
Bort62's Avatar
Now On our Stock Dual plane Manifold, a Open Spacer Would Cost Torque, and Questionably add to High end, Correct ?
A better bet would be a Dual Opening spacer, Right ? or Would a 4 hole style Spacer Be best Yet ?
To be honest, I cannt Recall If Our Stock alluminum intakes are of a Four Hole design, or that of a 2 passage Dual plane. you would think with as many times as ive had that Damn Carb off I would remember, But I swear it evades me.
Thanks for any enlightement You may give
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
Old Jan 15, 2001 | 08:56 AM
ede's Avatar
ede
to go in to a little more detail i have a holley intake, i have to use an adapter to bolt a holley carb to it, i also want to run the spacer to keep heat away from the carb, both are open type. the spacer is the high dollar plastic stuff. my concern is i did increase my intake volumn quite a bit doing this and wondered about the preformance increase, or decrease from doing it.
ICON Motorsports
1st & 3rd
Old Jan 15, 2001 | 02:06 PM
Jester's Avatar
The purpose of a spacer is to fine tune a manifold. Adding an open plenum spacer will provide a little more high end than it would have normally. Adding a 4 hole spacer will give a little more low end torque. Either way, it helps, but it's not a huge differece.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Jan 15, 2001 | 04:46 PM
ede's Avatar
ede
well i guess what iwas really after was with the adapter and the heat shield i've added 2 inchs, will that hurt preformance any?
ICON Motorsports
1st & 3rd
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
