Holley 2-way pump on 3-way OEM setup
Old Feb 4, 2001 | 11:46 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
I purchased a Holley mechanical fuel pump that has one inlet and one outlet only. How would I hook this pump up to the OEM system of one inlet and dual outlet (one for fuel tank return and the other, larger to feed the carb). I was thinking of using a T-fitting on the outlet (maybe restricting the fuel tank return), but will my pressure drop? I hope I won't starve my engine at higher rpms.
George P. Lara
1984 "L69" A4
1994 LT1 M6
Member:
SCCA, SCFB, SC3GFB
Old Feb 5, 2001 | 06:42 AM
Jester's Avatar
Run one line from the pump to the carb, and one is return to tank. There should be some sort of directions or labels saying which is which.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Feb 5, 2001 | 07:43 AM
ERIC'86IROC's Avatar
I just plugged the return line to the tank.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Old Feb 5, 2001 | 09:45 AM
The ODB's Avatar
Yep, just plug off that return line. That pump is meant to work without a return.
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305/383 with Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, 3.25:1 rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, .462/.470 lift @1.5:1 ratio. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
NBrehm
Aug 25, 2015 11:49 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
