Carb wont go back Together properly.
Old Feb 6, 2001 | 09:32 AM
Bort62's Avatar
WEll, I put the JB weld On the plugs as RB suggested, But I got a little over Zewalous an accidentlaly put It on One I shouldnt. Hence the TB would not Attach to the case Right. SO i took the grinder too it and removed ll the JB weld, and it still wont line up!
I got quite abitious with the grinder and Its still not working, So Im not sure what to Do!
Its the little tower circled In Red. Ive ground it down past where I put any JB weld, its actually smaller than Stock Now....
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
[This message has been edited by Bort62 (edited February 06, 2001).]
Old Feb 6, 2001 | 01:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I would guess that you've got something else hanging you up, like a dangling rod or the like. From the picture, there isn't anything in that area that would hang up the throttle plate on the bowl. If the gasket fits, the two should go together.
However, from your picture, I would be a little concerned about the grinding you did on the adjacent passage. That little rib is intended to compress the gasket and produce a tight seal. The sealing surface may have been compromised. I don't recall off the top of my head what that passage goes to, but I'd guess some vacuum supply.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, hi-flow cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
