How bout the "Camaro Conversion Kit" in a M5?
Old Feb 11, 2001 | 12:37 PM
Satan87Z28's Avatar
The kit is designed for a 82-87 LG4 with auto but what about swapping it in a car with a T-5. What all would I need to do to the T-5 to handle the power, or what else needs to be done in order for the car to run with the new motor correctly. The said one for the manual is said to be in the works but who knows how long that could take or if it would happen. A lot of you guys have LG4's w/T-5's and this kit sounds sweet.
Old Feb 11, 2001 | 06:47 PM
Damon's Avatar
It should go in with minimal changes. I'm sure SOMETHING is going to need to be modified but it's still a Small Block Chevy at it's heart. Just make sure the flywheel will work with the later style one-piece rear main. I know there are differences with flexplates between the two styles so I bet flywheels have differences, too. That's the only thing I can think of off the top of my head.
Oh yeah- make sure the block is drilled and taped near the oil filter for the clutch stuff that usually attaches there. I don't know when Chevy went to hydraulic clutches or if this will even be a problem at all with your swap but you might want to research it a little.
94 Firebird Formula M6- No options but Z rated tires. Daily driver. No mods over $10 and no more mods planned. 13.5@105.
79 Malibu "beater" w/junkyard 400 SBC, now only for boat towing duty, or for sale if anyone wants a 400 SBC that comes with a free car!
Grandma's old 78 Malibu (33K miles!) with a fresh 383, tweaked QJet 4bbl, decent heads and a mild cam. No runs yet- motor installed as of 2/11/01. Nitrous to be installed soon.
Old Feb 12, 2001 | 12:21 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
1984 was the first year of hydraulic clutches in the F-body.
92projectcamaro
Sep 29, 2015 07:07 PM
bbsr72
Sep 27, 2015 05:55 AM
89bird2.8
Sep 18, 2015 07:46 PM
Jetmeck
Sep 4, 2015 12:29 AM
