performance induction system
Old Mar 10, 2001 | 06:02 PM
Paul_Hughes_87 T/A's Avatar
Car: Chrysler 300c
Engine: 5.7L Hemi
Transmission: 5spd auto
Axle/Gears: 2.89
what do you guys think of the product and what gain could i get if i made my own system with a ho air cleaner
1987 Trans AM
305 LG4 5.0L
WS6
700R4
137,000km or 91,333miles
Black on gold trim
t- tops
K&N
Flowmaster 80 series
Sony X-plod deck
prestige 6 x 9s
2 crunch 10" bandpass subs running off the uq7 amp from the factory subs (which i blew with those amps)
Old Mar 10, 2001 | 07:58 PM
The ODB's Avatar
If you make your own and make it right, there is no reason you can't gain 6 - 8% in power from it.
[This message has been edited by The ODB (edited March 10, 2001).]
Old Mar 10, 2001 | 11:18 PM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
any suggestions where i can put the intake?
Old Mar 11, 2001 | 07:26 AM
The ODB's Avatar
relocate your battery if necessary.
run a single smoothe 4" tube from your filter box down one side (driver or passenger) of the engine bay.
Cut out the metal wall beside your radiator (right behind your headlights) to run the tube through.
Mount the pickup in front of the airdamn where there is highest pressure. You may want to pull the radiator so you can reposition your airdamn at a slight angle towards the pickup.
Insulate your air-feed tube from conduction & radiant heat by using layers of fiberglass & reflective stainless tape. Also insulate your air-filter box. The whole system should be well sealed, so you will need a thick rubber gasket between your airfilter housing and carb. Tapping the carb for a bigger aircleaner stud will help seal it.
Old Mar 11, 2001 | 03:00 PM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
should i use a single or dual snorkle system?
Old Mar 12, 2001 | 02:38 PM
Bort62's Avatar
Anyone else Notice that Their Initials as
P.I.S. ?
ODB, what material Do you suggest For the Ducting ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 12, 2001 | 02:53 PM
The ODB's Avatar
for the money PVC tubing is good. It is smoothe inside and is a good insulator.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Formula_88AE
Sep 3, 2015 01:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
