Milling choke tower on Holley 3310...?
Can I remove the tower with a Dremel tool or saw or does it really have to be milled off? I am hoping to improve airflow since I'm using a drop base aircleaner to clear stock hood and I think my high RPM power may be suffering.
I agree that a K&N lid should help. Now can I remove the choke tower myself or do I need a machinist to do it?
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
You can remove it yourself. I used a dremel..didn't take very long. I've seen dyno tests where milling the choke tower gained I think it was 9hp.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
JSP Motorsports
ICON Motorsports
I think milling the choke tower may have little affect if you have a tall aircleaner. However I am using a drop base air cleaner and a 3" tall element for hood clearance. Between the air cleaner lid and the top of the choke tower there is only about an 1-1.5 inches of clearance. It's not on the top of my priority list I was just curious.
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
