Burning Oil
Old Mar 29, 2001 | 09:05 PM
CAMARO82's Avatar
Burning Oil
I have an 1982 Z28 Camaro and It seems to be burning oil. When My car gets to around 230 the oil pressure goes down and My car seems to smoke non-stop. So could it be that I need to change oil weight. I have straigh 40W in it now I thought maybe I should go thicker. Maybe like 20W-50? Please Give me info or anything else you may think is wrong
Old Mar 29, 2001 | 09:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not sure why you put this on the carb board, other than your car having a carb; but, sounds like your engine is worn out. A thorough overhaul will cure it.
Are you saying your coolant temp gets up to 230 and stays there? That's a sure path to an early grave.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Mar 29, 2001 | 11:10 PM
CAMARO82's Avatar
It is a new engine but It is broken in because when I first got it it wasn't burning any oil then all of a sudden.. it started. It seems that my oil gets thin and my oil pressure goes down. My car does just stay at 230 I live in the desert it goes up and goes down
Old Mar 29, 2001 | 11:23 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Hey Camaro 82 I am from around El Paso ,Tx to. Who did your rebuild? Maybe I know the place or individual. What color smoke is coming from exhaust?White would be vaper(moisture),blue would be oil and black would be fuel. It could be a blown head gasket.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,kickdown kit and tranny oil cooler. Will install 3.73's later on and might go with a more aggresive cam.
Old Mar 29, 2001 | 11:26 PM
Car: 86 z28
By the way 230 is too high a temperature. I am only getting to 195 degrees. At idle it might go up to 210 but as soon as I start moving it goes back down to 195.
383 86 Camaro Z28
Old Mar 29, 2001 | 11:28 PM
CAMARO82's Avatar
It is bluish white but It smells like gas sometimes and oil othertimes so.. We have a Car club for Thirdgen Camaros and Firebirds . I
Am getting tired of my car smoking maybe I just need to change the oil weight because my car can be warm sometimes and it won't burn.
Old Apr 1, 2001 | 05:53 PM
82camaro's Avatar
Car: 82 camaro SC
Oil weight won't fix anything. 230 is a bit warm. Is your pcv system working? How much oil is it burning. 1 quart in 500 miles or something?
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
db057
Apr 28, 2019 07:45 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
my86bird
Oct 23, 2015 12:20 PM
CatmanFS
Sep 19, 2015 09:00 AM
