Too Lean?
Old Mar 19, 2001 | 05:54 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Too Lean?
Recently my edelbrock carb. as be backfiring when I first put in under load even letting it warm up. I readjusted the choke. I have also had a coolant temp. problem lately and was told the engine running lean could cause the temp. to rise. Could this be why the carb. is backfiring. How do I fix this. Which way do I adjust the air/gas screws on the carb.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old Mar 20, 2001 | 07:12 AM
The ODB's Avatar
the screws are for idle air fuel mixture only. If your idle was too lean, it simply wouldn't idle, so it's not that.
First make sure everything in the carb is clean and working properly before trying to adjust the A/F ratio. A clogged air bleed will give you too much fuel. A leaky booster gasket could give you not enough fuel. Most Edlebrock carbs come jetted very close to correct from the factory.
backfiring and temperature problems sound more like an ignition problem than a carburetor problem.
Old Mar 20, 2001 | 10:29 AM
Car: 99 Formula
Axle/Gears: 342
But when I had my cc q-jet on there it didnt' backfire at all.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
Old Apr 2, 2001 | 11:01 AM
FastBroker's Avatar
How about a vacuum leak somewhere??? How's your vacuum at idle look? How high/low is it, I mean?
Old Apr 2, 2001 | 09:12 PM
82camaro's Avatar
Car: 82 camaro SC
the cc q-jet also has a distributer to go with it. You installed the non-computer carb and a non-computer distributer. Your whole combo is different--you can't compare the two. Make sure your timing is correct, I would try around 8 base(about . What is your base/total timing? Vacuum leak could be the problem. Non-functioning or poorly functioning accelerator pump will cause a lean condition and possible backfire. In the case of my holley, a broken accelerator pump check valve. But that's another story.
Advance/retard the timing a bit and see if that helps.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Apr 3, 2001 | 11:08 PM
The ODB's Avatar
a mechanical problem like a sticking, bent, or broken valve will cause backfiring under load.
F-body-fan
Jan 12, 2023 01:49 PM
db057
Jan 10, 2020 08:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
