How are you guys plumbing your inline fuel pumps
Old Apr 22, 2001 | 12:18 PM
AustinT's Avatar
Ive been searching on the board And have found that the back of the rear seat is a good place to put a inline Pump, But how are you plumbing them into the fuel line.
Old Apr 22, 2001 | 08:56 PM
Damon's Avatar
If you can find an easy-to-reach section where the fuel line already has a short piece of rubber fuel line from the factory then patching in there is the easiest way to go. Otherwise, just cut out a section of the hard line near where you pan to mount the fuel pump. Make sure there are no kinks or hard bends in the line (hard or soft line) when you are done.
Basically, it's dealers's choice on this one and convenience is king.
Old Apr 23, 2001 | 12:03 AM
AustinT's Avatar
Thanks sounds easy enough. Can I power the Pump with the Wire that use to go to the Intank pump?
SHould I go with the Holley or Carter?
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
