My fuel pressure has been moving on me. I set it at 8, was at 3 today so I set it back up. I have the stock tpi fuel pump with mallory 3 port regulator. I figure my 87 fuel pump might be the problem, what do you think ??
Is the jam nut loosening on you? Just wondering I'm installing the mallory reg today. But I have the tbi fuel system, so maybe since it's not such high pressure, max of 15 psi I think it won't be a big problem for me.
It's a pretty simple design. About the only thing that can go wrong internally is the diaphram could tear/leak or the the spring setup would get dislodged or something. A leaky diaphram would make the pressure higher I think (if I'm thinking about it right), something to do w/ the spring/jam nut setup is all I can think of that might lower pressure.
I suppose the plugs in the extra ports could be leaking a bit after some time has passed etc. Mine did that, had to torque em down real good w/ some locktite.
But to directly answer your question no, I haven't any such problem w/ my Mallory regulator. Pump problems would be my guess.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
well so far I've ranged from 3-12 on start ups where it has been set on 7. I can only imagine what it is doing while I'm driving. The fuel pump is old, so I guess that will be the plan of action. I remember hearing people running an in-line electric pump through the existing disengaged stock pump, anyone point me in the right direction?? thanks
I recently installed the mallory fuel regulator in the switch from TBI to Carb. Once the initial leaks were fixed no more leakage. Pressure is set to 6.5 psi. IF I start to have problems I'll let you know.
My regulator wont keep the same pressure. It goes from 4-10 psi and the adjusting nut is not moving. Im looking at a inline pump
I've heard of similar problems before with that reg. The BG was better, but still gave me some problems. Pressure would drop as the car gor warm...so I had to set it almost TOO high at idle and startup. The stock pump may have been the problem..I don't know. I got rid of them both and did an elecric inline from summit.
I too have heard of pulling through the stock pump..however..it WOULD NOT work for me. I had to drop the tank, take out the pump and put in a pickup.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
[This message has been edited by Jester (edited April 22, 2001).]
JSP Motorsports
ICON Motorsports
I have the mallory and at first it wouldn't hold a steady pressure and then I cranked the nut and it was fine.
Jester what year is your car? My 1983 CFI-car wouldn't let any fuel by the pump either.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
future mods:
Damn, this is an old post that someone dug up, lol.
I still have not had any problems w/ my Mallory regulator.
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Quote:
<font face="Verdana, Arial" size="2">Originally posted by super83Z:
</font>
It's a 90, was a 305TBI. <font face="Verdana, Arial" size="2">Originally posted by super83Z:
</font>
