What is a good carb to use w/ a 350
Old May 8, 2001 | 02:36 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
I am putting a carbed 350 in my berlinetta, i am just curious as to what carbs you guys prefer. i want something somewhat on a budget, not a speed demon, but i have decided against the q-jet cuz it is really shot to crap and i decided i dont want to mess with it. i also would like to get fair gas mileage, similar to a q-jet, but something better. thanks
Old May 8, 2001 | 03:01 PM
fast iroc's Avatar
What have you done to the 350?Does it have exhaust?What gear ratio do you have?
85 iroc with 305 weind single plane intake 650 double pumper, msd crap,holley mechanical fuel pump,cam is 230 duration 453 lift, 350 turbo tranny, 2400 stall soon to be 3000, 125 horse shot of nos, 4.10 gears, lower end is built and i shift the 305 at 6500 just for you 305 doubters pull up next to this 305 and get a little
Old May 8, 2001 | 08:00 PM
it is gonna be a 350 with around 320 horses. headers, vortech heads (not aluminum), performer intake for vortech's, probably stock gears for a while, real dual exhaust with dual flows, open element filter, and a lot more i cant think of right now. it is kind of on the drawing board, i am perfecting what i should do with it to get the most for my money, that is why i am on here lol. stock my 82 had a weak 305, i wanna blow people's doors off and leave em wondering "that was a 305 with 145 horsepower?" hehe
Old May 8, 2001 | 08:52 PM
Demon Z28's Avatar
Car: 2001 Camaro SS
Engine: Almighty LS1
why not just get a normal Road Demon 625? those are fairly effective up to 400hp
Old May 8, 2001 | 09:58 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I just snagged a 625 cfm Road demon for my Vortec (note there is no h, VortecH makes superchargers) headed engine. Put it on tonight and did some prelim tuning, full report on how it drives tomorrow. I had a 750 holley that I never felt good about on there before... I found it interesting that the Demon came w/ nearly the exact settings as far as jets, accel pump shooter size, vac sec spring, etc right out of the box that I've spent a while tuning with and finally ended up with on my 750 holley...
CHP got 390 hp w/ the 625 cfm Road Demon on a Vortec headed motor... Cost is $299 in Jegs.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited May 08, 2001).]
Old May 8, 2001 | 11:44 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I vote HOlley. A 750 vac. secondaries would be a good choice. Also do away with the metering plate and go with a metering block on the secondary side. The metering block for the Holley is around 25.00$ It's very important to have the correct jets on your setup or else you will get ugly performance out of your engine. Tuning is everything.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression 186 casting Heads,234dur.488lift exh&int,Edelbrock performer intake, Holley750 vac.sec 400 crank,flat top pistons,edelbrock valve springs and lifters,tranny shift kit,2500 stall converter. Will install 3.73's later on and might go with a more aggresive cam.As of 4/01 added Hooker Headers,2.5inchpipes with 40 s. Flowmasters.Ignition upgrade include: MSD Coil and MSD module.
Old May 9, 2001 | 09:50 AM
fast iroc's Avatar
I'll have to agree with big 454 go with a 750 vacuum secondary not a mechanical.With those stock gears the vacuum secondary would run alot better.
85 iroc with 305 weind single plane intake, 650 double pumper, msd crap,holley mechanical fuel pump,cam is 230 duration 453 lift, 350 turbo tranny, 2400 stall soon to be 3000, 125 horse shot of nos, 4.10 gears, lower end is built and i shift the 305 at 6500, just for you 305 doubters pull up next to this 305 and get a little
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Zell1luk
Sep 29, 2015 10:36 AM
RedLeader289
Sep 23, 2015 06:50 AM
