Classified Ads Feedback Board Use this board to discuss your Classifieds transactions, buyers, and sellers. Do Not post ads here, they will be deleted on sight and without notice.
Posting A Classified Ad
Old Dec 3, 2002 | 10:17 PM
HurtHorseZ28's Avatar
I bet many people have attempted to "log in" many times and keep getting the page that repeatedly says, "You are not logged in".
I've posted questions before, and nobody seems to want to answer me or fix this problem.
So after much frustration and searching, I found this:
Tuesday, May 28, 2002
If you're having problems with getting logged out of the board and are forced to log in all the time, or if you can't post a Classified Ad or post a Readers Ride, do this:
Log in to the board.
Click on the USER CP link.
Click on EDIT PROFILE.
Make sure "Automatically login when you return to the site? (uses cookies)" is set to YES.
Make sure "Browse board with cookies?" is set to YES.
Then click on SUBMIT MODIFICATIONS.
Now would be a good time to DELETE YOUR COOKIES. After you log on again, everything should run properly for you.
>>Worked for me after doing this<< :hail:
If you still can't post a Classified Ad, then keep reading:
You are probably running a software firewall on your computer and you have "Browser Privacy" enabled (or something to that effect that hides your browser info and referrer info). Disable it. Go to the webpage that your software company maintains if you need help figuring it out. You can re-enable it after you're done posting your ad, but you'll need to disable it if you want to post again.
Those of you getting Error 502 messages all the time... it's nothing I can fix. The proxy server you are behind is overloaded and is giving you the messages, not thirdgen.org.
-Try it, it worked for me. :lala:
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tglennon11
Sep 23, 2015 05:30 PM
Strick1
Sep 6, 2015 02:21 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
