Classified Boards
View All Announcements (2) Announcements in Forum : Classified Boards
Jan 29, 2008 until Mar 1, 2027
JT's Avatar
JT
Community Administrator
Using the iTrader System
ThirdGen.Org offers the iTrader System to members so they can rate and review transactions between buyer and seller that take place on our Classifieds. The iTrader System is much like eBay's feedback system.
ThirdGen.Org strongly advises that you not only perform a search on the member you are considering a transaction with (especially in the Classified Ads Feedback forum ), but to also review their iTrader score.
Viewing the iTrader score of a member
Viewing the iTrader score of each member is simple as their iTrader score appears inside each of their posts, as illustrated below:
The bold value between the brackets of the "Classifieds Rating" represents the member's iTrader score. To thoroughly review the member's feedback, or to rate the member, you must click on the bold value that is between the brackets to be taken to their feedback profile.
The illustration above is a view of a member's iTrader feedback profile. You can view details of each transaction that a member has been rated for, as well as scores for Negative, Positive or Neutral.
Note: If a member has been rated by other members, you will see a Rating Summary with a list of each transaction and rating that the member has been rated for. Under the Rating Summary section, you can click on a title of a listed transaction to view any notes between both parties that were left for that particular transaction, as well as the ability to view the thread that the member was being rated for.
Rating a Member:
1) To rate a member on a transaction that took place on our Classifieds forum, you must first find the thread that the transaction had originated from.
2) Once you have found the thread that the transaction had originated from, click the value in the brackets for the "Classifieds Rating: (0)", which appears in the left side of the screen of the post of the member you are going to rate.
3) You are now viewing the member's iTrader feedback. Click on the link "Submit Feedback For (member's name here)", as the illustration below shows:
You are now viewing the submission form that will be used to submit the feedback for the member you are rating:
4 A) From the drop-down menu, select the party you were in the transaction (Buyer or Seller)
4 B) From the drop-down menu, select the rating you wish to give for the transaction (Positive, Negative or Neutral)
4 C) In the comment box, enter in a brief description of the transaction, such as comments like "Great communication", "Smooth transaction", "Would deal with again", etc.
4 D) In the "Deal thread URL", enter the URL of the thread that the transaction had originated from. The URL is the web address for the thread that the transaction had originated from.
To find the URL/Address of the thread that transaction had originated from, open a new browser window/tab to find the thread that the transaction had originated from.
Once you have found the thread, find the URL/Address in your browser's address field (top section of your browser) and right-click your mouse over the address, select "select all", then select "copy". The address/URL of the thread should now be copied to your operating system's clipboard.
Next, go back to the window/tab in your browser that you were using to enter the feedback submission form. Right-click your mouse inside the "Deal thread URL" and select "paste". The address/URL of the thread should now be posted in the "Deal thread URL".
4 E) Add any comments you wish to include, that are relevant, to the transaction in the "additional comments" section.
4 F) Click on the Submit Reply button to post the rating.
__________________
JT
Forum Jump
