92 convertible frame on a 88
Old Sep 28, 2003 | 12:50 PM
IROCVert88's Avatar
Would this work. Found a really good deal on a 92 Frame with new top and just need to know if it will work on my 88 Convertible.
Old Sep 28, 2003 | 03:29 PM
89convertIROCer's Avatar
Engine: TPI
There was a design change during the 1988 model year for the top latches at VIN #181698 to the 2nd design according to my Chevrolet Camaro 1982-1992 Parts & Illustration Catalog. I believe the bracket receivers riveted to the front windshield headerbar were changed also.
Check your VIN to see if you have the 1st design or 2nd design top latches on your 1988. Not sure, but possibly you may be able to put the 1st design latches onto the later ragtop frame which would allow it to be latched in front.
The B-piller mounted pivot point setup is the same.
Old Jan 18, 2004 | 07:07 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Moving
Old Jan 26, 2004 | 08:26 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I put a 91/92 style top frame on my 89 with no problems. Everything lined up. I have a set of 91/92 pieces that bolt to the windshield header if your pin alignment/type is different.
83RDRACR
Mar 26, 2016 08:13 PM
camaro1185
Oct 26, 2015 06:51 AM
maroman34
Sep 14, 2015 11:15 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Stryker412
Sep 7, 2015 09:11 AM
