lights in sail panels?
Old Jan 30, 2004 | 05:15 PM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
I just got my sail panels back from the upholstry guys and thought about adding some interior lighting by poppin in a light on each panel. Ideas? Recommendataions? thanks
Old Jan 30, 2004 | 06:16 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
Asc finally did this in '91 or '92 I believe. What i did was remove the ashtray in back of the center console and put a light in there. This way I didn't alter the panels on the car (which are very expensive to replace).
Old Jan 30, 2004 | 07:01 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
Zedder1990, Where did you tie into the wiring for the light in your console. Putting a light there was an EXCELLENT Idea!
Thanks for sharing!
Speedy
Old Jan 30, 2004 | 07:26 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
My 92 has lights in the sail panels, and I believe 91's do as well. They definatley come in handy!
Old Jan 30, 2004 | 11:03 PM
91zconvt's Avatar
Car: 87 Iroc
just 92's had the lights
Old Jan 31, 2004 | 07:51 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
lights
Any pics of 92 lights in panels? Also, what light was used to replace ashtray? I need to do something. I have already upgraded rearviw mirror with map lights that I tied in with the "dome" lighting.
Old Jan 31, 2004 | 02:49 PM
There ya go, best I have. Took that when I put the seats in a while ago.
Old Jan 31, 2004 | 05:09 PM
Engine: LB9
I went to a junkyard and picked up a couple of rear hatch lights(I believe these are the same ones they use on the '92 sail panels).I had an extra under dash panel that I cut up to fill the area once the ashtray was removed. I then cut an appropriate sizedhole in that piece of plastic and mounted the light in it. I ran wires up underneath the dash near the fuse box and spliced into the wiring for the rear view mirror lights(orange and white wires on my'90).Now the backseat light functions with the rest of the interior lights.
Old Jan 31, 2004 | 06:53 PM
Car: '90 RS Vert
Engine: 305 TBI
Z E D D E R 1990
Thanks for the details of that install. I will be attempting it soon!
Speedy
Old Feb 1, 2004 | 01:12 PM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
lights in trunk?
Great info. I think thats what i will do also. while on the subject of lighting. Are there trunk lighting ideas out there as well?
Old Feb 1, 2004 | 02:06 PM
91zconvt's Avatar
Car: 87 Iroc
...Sure are; buy a flashlight
Old Feb 2, 2004 | 10:03 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
lighting
lookin for more...but thanks for your input.
Old Feb 2, 2004 | 10:38 AM
Your trunk doesent have a light? Every one Ive seen including mine has had one in the factory location just like any other thirdgen.
Old Feb 2, 2004 | 12:27 PM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
lights
no light at all...I am not the original owner, so who knows what could have happened. where is "factory location"?
Old Feb 2, 2004 | 05:20 PM
Car: '90 RS Vert
Engine: 305 TBI
The factory location is right in the center of the plastic rear trim piece - the one that covers the entire rear section of the car. Are you sure there is not a light there? It would seem pretty unique if you did not have it there. I've not seen those for sale individually on ebay but they should not be that hard to come up with... Even if the light itself were not in place I would be surprised if you did not have the wiring already run to the location.
Old Feb 24, 2004 | 10:18 AM
RocVert's Avatar
Car: 67 RS/SS 91 Z/28 vert
My 89 vert doesnt have the lights, but I have a 92 vert parts car
that does, I was going to swap them into my 89.
they look similar to hte rear panel lights
A suggestion for you would be to find 2 similar lights (I would look at stock rear trunk panel lights for a third gen)
Or go to the Boneyard and just get 2 similar lights that that will pop in a hole.
then all ya got to do is cut a hole drop the lights in and tie it into the interior lights. (should look good)
hey I might have some extra light from a rear panel, if ya want em they are your's. (will send em for the shipping costs)
Old Feb 24, 2004 | 10:31 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
lights
Thanks...but I am going to go with the modified ashtray light in the back of the center console. (I just finished re installing my sail panels). If you have an extra hatch light, I'll take it. Let me know shipping, Edina 55435 or if your in the cities, I can come get it.
Old Feb 24, 2004 | 10:39 AM
RocVert's Avatar
hey cool, I'm bout 75 miles south of ya in Lake City Mn.
I will dig one up in the garage at lunch today and get back to you
I have lots of vert parts if ya need anything else.
send me your address so i can ship howel@hearthnhome.com
ps since your in the cities you have found the local Minn fbody
web site havent you, mnfbody.com lots of good local stuff there
Old Feb 27, 2004 | 04:43 PM
serpentineocean's Avatar
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
Me and my friend both have matching 91 Convertible RS's and they both have lights in the rear sail panels. So i do believe 91/92 did. Although this is the first time i learned that some years didn't.
Old Mar 17, 2004 | 12:06 PM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
light in console
I took zedder 1990's idea about putting a light in the console where the ashtray is and went on a quest for the "perfect light". I found the light(s) out of a 96 dodge van. The black textured trim matches perfectly, its aircraft style,and fit with minimal dremmeling. It looks great...no pics yet. Anyway, if anybody is serious about doing this, send me a pm and I'll send you a light. I went back to the boneyard and pulled out the remaining two.It will be a couple of weeks til you get it though...going on vacation.
Old Mar 17, 2004 | 12:34 PM
91zconvt's Avatar
Car: 87 Iroc
Later '91's and 92's had them. Early production '91's did not. Mine does not.
Old Mar 17, 2004 | 11:22 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
my '92 has them original equip.
Old Apr 5, 2004 | 07:31 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
From a 91
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6763
Old Apr 5, 2004 | 07:47 PM
91zconvt's Avatar
Car: 87 Iroc
Maybe it's because mine aren't leather, but they don't look like that. They do not have that stripe.
On another note, if the price doesn' get to high on those, I'd recommend that someone ****** them. Anyone. They're getting really hard to find...at a decent price, anyway
Vintageracer
Jan 10, 2020 05:33 PM
GTAman
Mar 15, 2019 11:40 AM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Omega
Aug 10, 2015 12:46 PM
