Getting the window tighter to the top?
Old Feb 7, 2004 | 04:21 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Im having some major leakage which usually ends up in the d/s rear passenger area... sometimes up to 1" of water! I know where its coming from, but not sure what to do about it...
Where the back, vertical part of the window seals with the top, its not very tight at all and you can easily put your finger in there. Anyone know of a way to tighten this up? Id rather not mess with the window track, but Ill probably have to.
Old Feb 9, 2004 | 02:54 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
I went and look at my top and didn't see anyway to adjust the top lower to meet the window. I'd say you window isn't going all the way up. Sorry I can't be of more help.
Laters,
Conrad
Old Feb 9, 2004 | 05:05 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
Maybe I'm just dense or maybe it's been a long day at work...
Could you please be a little more specific about where the leak is coming from?
Old Feb 9, 2004 | 05:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Go here and check this article out to see if it helps you any.
https://www.thirdgen.org/newdesign/t...owadjust.shtml
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
