wiring mystery in trunk
Old Feb 28, 2004 | 11:48 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
I found where my trunk light is supposed to be. Got a hatch light, hooked it up and...nothing. But, when I jumped another two prong connecter hangin around in trunk, it went on. There is a rectangular hole to the left of the hatch grasp with nothing there. What is supposed to be there and would that plug into the other two prong connecter? Also, I have a wide rectangular black connecter with a black/yellow wire and black wire (looks like it would hold a fuse or something) that is not connected. What is that? Last problem, promise, took out center brake light to check bulbs...it was not connected and cannot find where to hook it up to. I have the whole trunk torn apart!
Old Feb 29, 2004 | 07:32 PM
chuck88iroc's Avatar
Car: 1988 IROC-Z Convertible
Engine: 305 LB9
Transmission: MK6 5-speed
Axle/Gears: G80, G92, GM3
The black contactor is the hatch contact assy. for the high level stop light (on trunk lid). It should contact another contact assy. just to the left of the truck hatch pull down actuator.
The trunk light should have an orange wire (power) and a white wire running to the light switch. From the light switch a black wire should run to ground.
Chuck
Old Mar 1, 2004 | 08:56 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
wiring mess
thank you for the black connecter mystery. got that working now. I have it temporarily rigged up. Is that a standard connecter I can get at a parts store? Any idea on if I am missing a switch to activate the trunk light?
Old Mar 1, 2004 | 12:07 PM
Engine: 305 LB9
Unfortunately I doubt very much that an auto parts store would have the hatch contactor assy for the stop light. You will likely need to try Chevy.
There should be a slider switch just to the left of the cargo compt. light. This switch should have a white wire coming from light and a black wire going to ground attached to it.
Chuck
Old Mar 7, 2004 | 09:28 PM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
rear hatch light switch
Went to the boneyard and found a great switch for the trunk/hatch light. Its a spring clipped black rocker panel switch that came out of the dash of a 93 pontiac transport. I had to dremel maybe 1/4 inch to make it fit, but it looks terrific and works great. Also I dont have any bolts and/or screws to hold the plastic trunk liner pieces in place. What do I need? thanks
Old Mar 8, 2004 | 08:26 PM
Engine: 305 LB9
I have never had the stowage compartment out of the trunk so I am not too familiar about it exactly is attached. I have only had the spare tire and rear panel out.
For the most part the three panels seem to be attached together by 4 large nylon screws. The holes for these should be pretty obvious as they are pretty big. Other than these the only other screws seem to be two small self taping screws through the top of the rear panel. One is near the high level stop light contactor the other near the pull down actuator. They are marked in the picture below.
Chuck
Old Mar 8, 2004 | 08:29 PM
Engine: 305 LB9
Sorry, I attached the wrong view. This one has the two small screws marked (I hope).
Chuck
Old Mar 9, 2004 | 08:31 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
trunk pics
thanks..i have the two top screws, but not the nylon ones. would you mind posting a picture of the inside view of the trunk lid as i dont have either connecter for brake light?
Old Mar 9, 2004 | 07:29 PM
Engine: 305 LB9
Here is a picture of the contactor on the truck lid. Hope it is the view you are looking for.
Chuck
Attached Thumbnails wiring mystery in trunk-high-level-stop-light
Old Mar 10, 2004 | 08:30 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
yes!
yes! this is the piece I am missing along with the trunk mounted counterpart! thank you very much.
diana227vegas
Jul 8, 2016 12:27 AM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Firebird sweden
Aug 16, 2015 05:02 PM
mx127
Aug 10, 2015 08:13 AM
