Educate me on how the top works
Old Mar 21, 2004 | 06:58 PM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
I just bought an '89 IROC vert, and need to go about repairing the top. When I hit the switch in the center console, I hear a popping noise, but nothing ever happens. I have to reach down inside the drivers side sail panel to push on a cable to release the tonneau cover. After that, I have to fold down the back seat and pull a cotter pin to release the back of the top. After that I can pull the back of the top up, lift up the tonneau, put the top down and close the tonneau.
Since I've never seen or used a third gen top before this, I have no idea on how this process is supposed to work. Am I close, or WAY off? And if so, what parts do I need to make it work right. Any help is appreciated.
Old Mar 22, 2004 | 01:56 PM
Guest
Guest
Posts: n/a
You're supposed to pull the cable first I'm pretty sure. It should release the top from the tonneau, shouldnt have to lower the seats and mess with the pin. It may need some adjustment there to work, its not the best design and it does bind some. Then you can lift the rear of the top up and pop the tonneau with the switch on the console.
Put the side windows down some before you do any of that. There's a rod or two up front that you can bend if you dont.
Old Mar 22, 2004 | 06:18 PM
DJCobol's Avatar
So that switch is supposed to release both the tonneau and the back of the top? What kind of parts am I gonna need to get this thing back in working order?
Old Mar 23, 2004 | 12:55 AM
Guest
Guest
Posts: n/a
The switch on the console is only for the tonneau.
I dont think you need any parts, just need to adjust the pin. I had to bend mine a little bit.
Frozer!!!
Jan 19, 2024 04:55 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
jharrison5
Aug 19, 2015 05:53 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Poncho92
Aug 7, 2015 08:15 PM
