5 inch spoiler?
Old Mar 25, 2004 | 09:04 PM
topless89rs's Avatar
Engine: 5.slow
5 inch spoiler?
i really want to put a 5 inch spoiler on the vert. will the center section mount on the trunk lid? if it does then i can just use fiberglass to mold the end caps to match the 5 inch spoiler right???? i e-mailed bruce about working this out but haven't gotten a reply yet. any ideas?
Old Mar 26, 2004 | 07:14 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Re: 5 inch spoiler?
I am currently in the process of installing the 5-incher on my '87 coupe (with third brake light).
Yes, with two modifications. The 5-inch spoiler, as well as stock three piece spoilers without the brake light uses six studs spaced equally across it. On the three-piece third brake light spoiler, the two center studs are spaced further apart. Bruce suggested to me to leave the spoiler intact and to drill two additional holes in the deck lid. I did not like this idea because the decklid structural support (underside) is double-thick at those locations with airspace between the sheetmetal. If you want to do this, you'll have to drill about 1-inch diameter holes in the support member to make sufficient room to nut the stud. In my case, I did not do this because I had to cut an access slot in the bottom of the 5-incher to install a third brake light within (more below), so it was easy to hack the two unneeded studs and install two in the proper location.
The other problem is you'll have to make some sort of provision for the third brake light. On 1986 and newer cars, this is the law. On a convertible, the only feasible location I can think of would be in the spoiler itself, especially with such a high piece. The good news is that with a lot of patience and ingenuity (I'm pretty good at fabbing stuff), a third brake light can be installed. The stock piece is not a candidate for this as the lens surface is slightly contoured (curved) and the back surface of the 5-incher is not nearly as curved. It just won't fit right. I am using a 48-LED light bar.
I suppose you could but I have no experience with fiberglass so I'm not qualified to answer this question.
My spoiler install should be finished this weekend while my family is in California. The bad news is they took the digital camera so I won't be able to snap any shots during the fabbing/install.... I did post a couple of pics of the third brake light install progress here:
https://www.thirdgen.org/techbb2/sho...hreadid=225336
I'll be posting pics of the completed install after I get my camera back.
Old Feb 27, 2006 | 12:49 AM
Firebat's Avatar
Anyone got a 5 inch spoiler on a camaro vert? Or is anyone working on it? I'm wondering if it would look ok.
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Oct 1, 2015 11:24 AM
