Hatch Motor fuse, Where?
Car: 1991 Z28 Convertible
Transmission: 5 Speed
I've tried to find the fuse used for the hatch pull down motor. Can't seem to find it. Any help out there?
Axle/Gears: 3.45, 3.27, 3.27
For Camaro the hatch release fuse is the #3 fuse (top row, third column from the left). For Firebird the hatch release switch is a separate in-line fuse adjacent to the fuse block. For Camaro or Firebird the solenoid release fuse is the #11 position (third row down, third column from the left). Pull off the hatch surround trim panel and check with a multi-meter or test light that you have +12v at the red with white stripe wire that is plugged into the blue wire.
Lon
Lon
GOT IT!!! Your were absolutely correct. Top row, third column. Once I pulled it, I could see it was blown. Put a new one in a listened to the hatch motor pull it down. This is especially rewarding as I replaced the motor and knew it worked (having jumped the leads before installing it). Thanks so much for your help. You saved me a ton of time.
Ken
Ken
Ghettobird52
Jul 5, 2024 11:18 PM
