Failed Emissions Help!!
Old Jan 15, 2005 | 05:44 PM
aldixie's Avatar
Car: 1991 RS Camaro Convertible
Hi,
I took the car in for inspection today and it failed on emissions,one front tire and emergency brake. It failed on the low speed emissions
The emission readungs were as follow:-
Standard Current
HC(PPM) 120 196
CO (%) 0.67 0.28
CO2(%) 14.3
O2(%) 0.8
NOx(ppm) 907 1472
DILUTION(%) >6 14.6
What I have noticed is a broken component in the engine bay,I think its the air control valve.Could this be the problem?
Have enclosed a picture.
Thanks,
Alex
Old Jan 17, 2005 | 05:52 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
YUP
That is the AIR control valve.
The AIR system pumps air into your catalytic converter and causes it to begin functioning sooner than if it were not present. After the car has been running for a while it should probably not matter...
How old is your Catalytic Converter? You can purchase a low restriction replacement for around 30 bucks and have it welded in for probably ten...
Speedy
Old Jan 22, 2005 | 03:52 PM
dual_88s's Avatar
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
Where in Texas are you? If around Plano/Allen area, I know a mechanic that is great on emissions problems.
PM me if you need/want more info.
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
6998poncho
Sep 25, 2015 02:56 PM
