Rear axle -- Manual vs. Automatic trans
Did automatic and manual convertibles come with different rear ends? I have two convertibles, one 5-speed and one 700r4 and want to switch transmissions. I heard that the factory placed a slightly higher gear ratio in the 5-speed cars. Do I also have to switch the rear axles? Or will I not notice any difference?
Thanks in advance.
Thanks in advance.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Other than the ratios, and the possibility of brake differences, they are the same on 3rd Gen.
If both are disk rears, they'll swap right over (same if both are drum rears).
Yes, manuals typically had higher ratios (3.23 or more) while autos seldom went as big as that.
Car: 1988 IROC-Z Convertible
Engine: 305 LB9
Transmission: MK6 5-speed
Axle/Gears: G80, G92, GM3
Originally posted by Lumberjack
I thought all verts came with drum brakes in the rear
Information on this can be found through the below link. Scroll down to where the individual years are detailed:
Tech Data
Chuck
1992 Trans Am
May 10, 2023 07:19 PM
