Squeaky Top
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
Squeaky Top
The top frame on my car makes so much noise when its up
Does anybody have any sudgestions on how to fix it?
Car: 1986 Vert Z28
Engine: SuperCharged 350
Transmission: 5 Speed Manual
Mine did the same thing for a couple months, and honestly i just 'PB Blaster'ed every joint i could reach almost every day for a month, and then used a white lith for a couple weeks (every other day abouts...)
Hadn't had a problem in almost a year now. But my front latches are pretty tight too, so if the squeek is comming from there, i can't really help ya.
Car: '89 Iroc Vert
Engine: 355 TPI
it make the most noise all along the top of the window from all the hinge points, but a good percentage goes away with the window up
I tried lube but only once I'll try some more
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
