Help with RPO CODES
Old Jan 26, 2006 | 09:50 PM
92TA's Avatar
Help with RPO CODES
Can anyone help with the missing codes below? Also, does anyone know how many 1992 T/A's were made. I see that some people break this number down the the color.... Does anyone have this info? Not sure if this is tru but I thought I would ask. I've heard tha the very last TPI cars made only had a blank badge on the TPI unit rather than having the Tune Port Injection badge... does anyone know if this is true? Thanks for all you help.
Link to my other cars:
http://www.cardomain.com/ride/2205262
AAA – 4-Way manual seat adjuster
AH3 – Adjuster, 4-way manual, driver seat
AR9 – European style front bucket reclining seats
AU3 – Electric locks
A31 – Power windows
BC8 – Interior door map pockets
B84 – Exterior body side molding
C60 – HVAC system, A/C
DG7 – Remote Side Mirrors
D3W – Speedometer gear
E5Z – Speedo adapter – delete
E9Z – Speedo key – delete
F41 – Firm ride handling system, front & back
GU2 – 2.73 Rear axle ratio
G80 – Limited slip posi traction
JG1 – Aluminum drive shaft
K34 – Electronic cruise control
K68 – 105 AMP Alternator
LB9 – 5.0 L HO V8 TPI gas engine
MD8 – Automatic 4-speed THM-700R4
MXO – Overdrive transmission
NA5 – Federal emission system
NP5 – Leather wrapped steering wheel
T93 – Tail and stop lamps
T96 – Fog lamps
UQ1 – Stereo provisions
VAN – Assembly plant – Van Nuys, CA
V73 – Fixed antenna
WS4 – Model conversion – Trans Am
Y99 – Sales and handling package
6ZX – Computer selected LF handspring
8NL – Computer selected LR handspring
9NL – Computer selected RR handspring
PW7 - 16x8 styled aluminum superlight wheel
1SC - Value group savings
AJ3-Restraint System, Front Seat, Inflatable
QPE-Tire all, p215/60r16/N BL R/PE ST TLAL2
AR9 - Front bucket seats manual reclining (European style)
10Q- Molding color artic white
IPC-
10U-Exterior color artic white
UB3-Instrument cluster (Oil, Coolant temp, Voltmeter, Tach, Trip, ODO)
52P-Wheel color, gold MET (91)
J41-Brake System, Power FR Disc, RR Drum
U1A-Radio, AM&FM Stereo, Seek/Scan, C.D. Player, Equilizer, Includes Clock
62T-Vinyl top color light beechwood metallic
U62-Speaker System, Dual FR and RR Coaxial
64C-Trim Combination, Light Beige Cloth
64I-Light beige interior trim
649-Seat belt color, light geige (9) (92)
D8N-Sensor, VEH SPD (D8N)
7ZX-
Y83-MERCHANDISED PKG, TRANS AM GT
Old Jan 30, 2006 | 03:22 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
7ZX : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
Old Jan 30, 2006 | 12:36 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
email GM asking for a restoration package, they'll send it in the mail and it's FREE, has all RPO codes, production numbers, various codes etc
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
